brake wear sensor
I hope this will be an easy question for someone here. I am new to BMW's myself. The brake wear light has been on. So, I replaced the pads(they were bad). Now how do I get that brake wear warning light to go off?
Thanks.
hey, you'll need to replace the sensor. it's like 10-15$ it fits into a little cutout on the brake pad and goes right throught the rear of the caliper. on the drivers side only...
good luck
You cant reset it if its been worn to far i believe. When mine went off, it would come on, then go off,the it just stayed on all the time. i think if u reset it while its is still turning it self on and off, u will be ok.
KB
