Mine starts up fine when I take it out of storage, but the next time I start it, the pump won't pump, and I have to slam my fist on the back seat to get the pump going again.
So, the pump works, but you split a line, so I would figure that there is a clog somewhere between the engine and where the line split. Have you changed your fuel filter? Was the fuel system releived of pressure before the car sat for so long? Gas sitting in fuel lines for over a year will turn to crap, and gunk up your lines. I would suggest pulling the fuel line at the pressure regulator and seeing it anything is flowing there. If you're getting fuel there, pull it after the regulator... If you think it's getting fuel, make sure you're getting spark. Pull a few plugs and see if the're wet or smell like gas. Might as well change all the plugs at that point... let us know what progress you've made.
