Hi, I am new to this forum with a 1989 325i 4-door luxury sports sedan
, and she is the one thats hot... She wont stop trying to overheat!!! List of things I have fixed to stop it:
1. Replaced the Fan Clutch ({Picture 2} Radiator hose clamp popped and the top hose rested on the fan blades stopping it from turning and burned out the clutch)
2. Replaced the thermostat with a stock temp rating
3. Put in a t-connect in the waterline {Picture 3} between the thermostat housing and the firewall/ heater box and connected a water hose full blast while the car was running at normal temp until all the water ran out clear.
4. Refilled the coolant 50/50 but forgot to release the bleeder on top the thermostat housing while I filled it up. (Does that mean is has air in the lines?)
5. Checked the forward aux cooling fan... It's fine
I am out of Ideas and I drive in stop and go traffic in the blistering heat of Charleston, South Carolina.. I am afraid that if I keep this up I am going to severely damage the engine
(it already has a little ticking? Valve Adjustment?)... Also I have owned the car for 3 years and I for one have not changed the water pump or timming belts on it... I have a list of other problems but this is the most important at the moment.... Any Ideas?
![Pray [pray] [pray]](/images/smilies/icon_smile_pray.gif)
![Mad [mad] [mad]](/images/smilies/mad.png)
